The following time is planned for the presentations:
- Invited presentations: 55 min with 5 min for questions
- Contributed presentations: 25 min with 5 min for questions
- Computation presentations: 20 min with 5 min for questions
A computer (MacOS) connected to the video-projector is available in the Théâtre and Salle des Actes for uploading the file presentations (pdf).
We recommend to upload your files before the beginning of the session.
Supports for A0 posters will be available in the Belvédère room for their presentations. The room will be open from 12h, on Thursday 15 June, to fix the posters on their supports.
Download here the book of abstracts
Contributed presentations |
Fabio Tanturri and Frank-Olaf Schreyer. Matrix factorizations and curves in P4 |
Scott McCallum, Adam Parusinski and Laurentiu Paunescu. Validity proof of Lazard’s method for CAD construction |
Alexandru Dimca and Gabriel Sticlaru. Computing the monodromy and pole order filtration on Milnor fiber cohomology of plane curves |
Yairon Cid Ruiz. Bounding the degrees of a minimal μ-basis for a rational surface parametrization. |
Thorsten Jörgens, Thorsten Theobald and Timo de Wolff. Imaginary projections of polynomials |
Carlos D’Andrea, Teresa Krick, Agnes Szanto and Marcelo Valdettaro. Closed Formula For Univariate Subresultants In Multiple Roots |
Akihiro Higashitani, Mario Kummer and Mateusz Michalek. Interlacing Ehrhart Polynomials Arising from Graphs |
Adrien Sauvaget. Hurwitz numbers and intersection in spaces of differentials |
César Martínez and Martín Sombra. An arithmetic Bernstein-Kusnirenko inequality |
Matteo Gallet and Josef Schicho. Counting projections of rational curves |
Michal Lason. On the toric ideals of matroids of fixed rank |
Xavier Allamigeon, Stephane Gaubert and Mateusz Skomra. The tropical analogue of the Helton-Nie conjecture is true |
Sergey Fomin, Dima Grigoriev, Dorian Nogneng and Eric Schost. On semiring complexity of Schur polynomials |
Mateusz Michałek and Emanuele Ventura. Finite phylogenetic complexity and combinatorics of tables |
Luke Oeding. Border Ranks of Monomials |
Niels Lubbes. Surfaces containing two circles through a general point in higher dimensions |
Simon Hampe, Michael Joswig and Benjamin Schröter. Algorithms for Tight Spans and Tropical Linear Spaces |
Jorge Caravantes, J. Rafael Sendra, David Sevilla and Carlos Villarino. On the existence of birational surjective parametrizations of affine surfaces |
Cordian Riener and Markus Schweighofer. Optimization approaches to quadrature |
Simone Naldi and Daniel Plaumann. Symbolic computation in hyperbolic programming |
Sandra Di Rocco, David Schmitz, Thomas Bauer, Tomasz Szemberg and Justyna Szpond. On the postulation of lines and a fat line |
J. Maurice Rojas and Korben Rusek. A-Discriminants for Complex Exponents and Counting Real Isotopy Types |
Carlos Améndola and Jose Israel Rodriguez. Solving Parameterized Polynomial Systems with Decomposable Projections |
Hamza Fawzi and Mohab Safey El Din. On the number of vertices of generic spectrahedra |
Anton Leykin and Josephine Yu. Beyond Polyhedral Homotopies |
Timo de Wolff, Sadik Iliman and Mareike Dressler. A Positivstellensatz for Sums of Nonnegative Circuit Polynomials |
Michela Ceria. Bar Code for monomial ideals |
Marina Bertolini, Roberto Notari and Cristina Turrini. Bordiga surface as critical locus for 3–view reconstruction in P4 |
Alicia Dickenstein, Frédéric Bihan and Magalí Giaroli. Regions of multistationarity in chemical reaction networks |
Elena Angelini. Waring decompositions and identifiability via Bertini and Macaulay2 softwares |
Teresa Cortadellas Benitez, Carlos D’Andrea and Florian Enescu. On the resolution of fan algebras of principal ideals over a Noetherian ring |
Martin Ulirsch. Tropical geometry of toric stacks |
N. Thieu Vo, Georg Grasegger and Winkler Franz. Optimal Curve Parametrization and an Application to Algebraic ODEs. |
Ethan Petersen, Nora Youngs, Ryan Kruse, Dane Miyata, Rebecca Garcia and Luis David Garcia Puente. Neural Ideals in SageMath |
Yue Ren and Tommy Hofmann. Computing tropical points and tropical links using intersections with affine hyperplanes |
Sebastian Posur. Computing Resolutions of Equivariant Modules |
Laurent Busé, André Galligo. Extraction of tori from minimal point sets |
Alessandro Amadori, Michela Ceria, Federico Pintore and Massimiliano Sala. On the discrete logarithm problem for prime-field elliptic curves |
Alberto Alzati, Cristina Turrini, Giuseppe Rotondo, Gianfranco Venturino and Iuri Frosio. A new model of avalanche transceiver |
Maria-Angeles Zurro, Macarena Ansola and Antonio Diaz-Cano. Semialgebraic Decomposition of real binary forms |
Aline Andrade, Simone Marchesi and Rosa Maria Miró-Roig. Orthogonal instanton bundles on P^3 |
Charles Almeida, Marcos Jardim, Alexander Tikhomirov and Sergey Tikhomirov. Families of Stable Locally Free Sheaves on Projective Spaces |
Indranath Sengupta, Joydip Saha and Gaurab Tripathi. Primary decomposition of certain determinantal ideals |
Isabel Bermejo, Eva Garcia-Llorente, Ignacio Garcia Marco and Marcel Morales. Noether resolutions in dimension 2 |
Ioannis Emiris, Clément Laroche, Christos Konaxis. An implicitization algorithm based on Chow Forms for codimension larger than one |
